Recently had to clean out the gas tank on a wd 45. When placing the tank back on, I moved some of the wires around
the solenoid. The tractor has been converted to 12 volts and has an alternator, and a keyed ignition switch.
Noticed one wire came out of a wire fitting attached to the back main post(the post being the main terminal to
the positive battery wire) of the solenoid (it is a four post solenoid, two main post, two smaller posts at the side) Placed it
back into the same round electric fitting. (This wire goes into the ammeter, then over to the ignition switch)
The back post of the solenoid had two wires attached to it, one from the positive side of battery, the smaller wire
went to the ammeter. Now the tractor starts but when the ignition switch goes back to on
position from start the tractor dies. I check fuel flow and carb, everything has good fuel flow, so it has to be
an electrical issue. I do not have a photo, but any suggestions as to why the tractor starts on start but dies
in the on position. And how do I correct it? Thanks for any response.
