I have a 1949 Allis Chalmers WD. My problem is with the hydraulic system. The original Hydraulic pump was bad. I bought a used replacement off EBay. The purchased pump is in excellent condition and looks like recently rebuilt. It came with the top valve, also looking in good condition. The replacement pump was installed and I used the valve that came with replacement pump. The problem i have is that as soon as the engine is started, the lift cylinders go up to their upper limit, regardless of the position of the lift lever or valve setting They lock and cannot be pulled down so obviously there is no path for the hydraulic fluid to flow in the opposite direction. I have 3 manuals plus the internet and nothing talks about this problem. There is plenty of information about the various settings and adjustments for the 3 modes of draft control and I've experimented with all of those but nothing I've done has any effect on the hydraulically locked lift arms. I'm looking for an old farmer or an old tractor repairman who can help me. These AC tractors have one way lift cylinders and utilize a single hydraulic line between the pump valve and the cylinders. So, the hydraulic fluid needs to be able to flow in both directions through that single line. Mine flows out but it doesn't flow back, as if there was a check-valve stopping the return. I installed all the replacement parts in exactly the same way as the original so nothing should have changed. SUGGESTIONS?
