lstockwell
New User
Hello, I'm hoping you guys can help me out! I recently got a 5020 Allis Chalmers. When I got it I was told the starter was on its way out, but I could get it to start still. I did a oil change, oil filter change, filled it with coolant, and did a fuel filter change. I'm not mechanically inclined at all, so I'm learning, but I didn't realize you are supposed to put some fuel in the fuel filter before starting, and I am recently learning how to bleed the lines. Thanks to a post and a picture Dick L posted, I found the bleed screw, got it bled there. I bled it until there was no more bubbles and a stream of fuel came out, I let the stream run for about 2-3 seconds just to confirm I got all the air. I also had the starter rebuilt when I did this. I got the starter back on, it was cranking, but not firing still and then I saw a spark from the negative terminal on the battery and now I can't get it to crank at all anymore. Any ideas on what I can do before I give up and call a shop? Thank you!
