My Case 841 has a Zenith 62 series carberator on it. Looking at parts book, they list a TSX 785 Marvel Schbler carberator as a replacement. The fuel inlet is on the same side for both carberators. However; the choke attachment is on different sides as is the throttle attachment between the two carberators.
Will the TSX 785 fit on my tractor ? Did they make different throttle rods for each carberator or will the same thottle attachment work on both carberators. The choke attachment is no problem since it ie a fexible wire attachment.
Interestingly enough the series 62 Zenith carberator was not available from the sources I looked at.
Thank you in advance for any help you can give me.
