I bought a 440H tractor with loader and backhoe, it's rough, runs but barely...
The throttle lever under the steering wheel, or the pedal dont seem to be working right not sure if linkage is damaged or??. I havent figured out how to control the throttle except with the choke (push-pull cable on dash)... I can get it to run unless there is a load then it dies. I'm confused with how it operates.
Same with the transmission, There are 2 levers, the one on the left seems to be Forward, Reverse and Neutral... the right a 4 speed gearbox But Im confused as I think the H in the 440 H means it had a 12 speed gear box, so wondering if there is some kind of OD/Doubler somewhere I haven't figured out...
Is Jensales a good site for getting manuals to learn how to operate / repair it, or are there better resources??
