Marshal51
Hello all, after searching everywhere it seems.. manifolds for a 930 CK gas are impossible to find. The 930 we have is currently using the A21357 cyl. heads with the LP intake (A9510) and exhaust numbers A24980 and A24979. The only tractor I can find that uses these exhaust part numbers is the 1200 4WD. Is this cluster of tractor parts going to hurt the motor or anything since its not what was supposed to be on the tractor? Could I just put the diesel/LP exhaust on since I already have the gas intake and this exhaust I could actually get about anywhere. Or would that hurt the motor at all? Thanks for any information on this.
As far as I know the 1200 was only made with the 451 turbo diesel engine. The gas intake is the hard part to find. If the diesel manifold will fit with the gas manifold go for it.
We've supplied several 930 Diesel Manifolds to replace the manifolds on 930 gassers. On these, the exhaust stack was in the front, not the center. The gas exh. manifold is drilled & tapped on the bottom so the intake can bolt up to it. The diesel manifold is not, but the clamps will hold the gas intake in tight to the heads.
It could be similar to removing the intake heat on a carbureted car engine. Summer operation should not be affected by deleting the heat to the intake manifold. You could get more carburetor icing while idling in cold weather. If really needed, a simple left side engine panel could be added to direct warm air from the radiator over the carburetor and the intake air pipe.
So we should be good to go since we have the LP intake just stick a LP/diesel exhaust on it. Have any exhaust manifolds? And whats your price for one?
I guess since it runs and drives now with a LP intake and diesel exhaust it should be any different once putting the Lp/diesel exhaust on.
I think they just stuck the exhaust off a 1200 on it since they couldnt find the gas exhaust. And it seems you can still buy this exhaust through case. Not sure why they didnt just put the LP/diesel 930 exhaust on it if they put the Lp intake on it though
