Case plow top link
mschwartz
Hello, looking for specs on the original top link used with a BER(I think) plow on a Case SC or DC tractor. Ultimately looking to purchase one if it was available but thought with good pics and measurements I can fabricate one to use until I find one. All of my eagle hitch tractors have a different version of a homemade top link mount. I am looking for the cast link that goes over the PTO and the swivel part that attached to it. I think that this may have only been used with the plows? Thanks for your help, Mike
(quoted from post at 17:19:41 03/26/23) Hello, looking for specs on the original top link used with a BER(I think) plow on a Case SC or DC tractor. Ultimately looking to purchase one if it was available but thought with good pics and measurements I can fabricate one to use until I find one. All of my eagle hitch tractors have a different version of a homemade top link mount. I am looking for the cast link that goes over the PTO and the swivel part that attached to it. I think that this may have only been used with the plows? Thanks for your help, Mike
Ill get some pics and dimensions later today for you Mike. CM
Been a busy here Mike
Here are some pics of the toplink bracket that you are in question of case part number 6181A. The bracket is 5 1/2 in. Square.. There are 4 -17/32 holes drilled in the plate 4 7/16 that is a crossed and up-and-down. The casting is 1 inch and a quarter thick and the PTO shaft boss is 1 and 7/8 inches long. The id of the boss that the top link connects to is 3/4 of an inch ID. Centerline of that hole is 4 3/8 from the top of the casting to the centerline of the hole. Please let me know if you need further dimensions. CM
Thank you for the pics and info. The one other measurement that would help me is the center of the 3/4 hole from the mounting surface of the plate. Thanks again for all of the info and pictures. Mike
