I moved the selection lever for draft and height control then went to raise the post hole digger higher pushed the lever up to where you change the selection now it will not go down
I did not read the warning about not moving the seletor till you hold the lever all the way up untill after the fact. How do I get the 3 point arms to work they are stuck ion the up position. Thank You
