hydraulic oil for case480b
I have hydraulic oil for my case 480b backhoe I know the rear takes 85/140.my question is does the shuttle when filled is that all I put in .there is a plate in front of shuttle I took it off and it was dry no fill area so in thinking shuttle filled will fill all the front I have high Tran for shuttle area any help will be sppreciated
So it's a 480b ck. Depends which unit you have. Mechanical clutch or hydro. Peaceful creek has the manuals reasonably priced. I have the manual for a 580b ck from PC. It's huge. If you say which trans you have I can look later, probably the same fluids as a 580, or someone here will know. Can try HEF too. That's heavy equipment, you know what the f is for. A lot more info on heavy stuff on their forum.
I have a 480E I have put the best grade of hyd trans oil available. In everything. Has worked for almost 30 yrs. And I use it in the trans and rear end of my D17 pulling tractor to.
