Trapperjoemo
New User
Having trouble steering. Cant find an appropriate repair manual. where do I access the brakes to check them out? The levers move freely, but it takes both hands to pull either lever hard enough to get even limited turning.
Thanks(quoted from post at 06:03:38 03/19/23) They are separate. Fill the transmission/differential to the side level plug & the final drive cases to their side level plug. Use Permatex #2 on the final case flanges. Have an eye for several (3?) 1/2" "body fit" bolts or holes that are supposed to help you accurately align the cases. Usually 10 o'clock, 2 o'clock & 6 o'clock. I use 1/2" rod to align things on assembly.
On the parts page I referenced earlier in this thread, I see some identical parts to the Case 310E that I have. Aftermarket pinions & other parts are available but 50% are improperly machined so beware. Bearings are fairly pricey too so you want to get the "stack" dialed in as best you can.
I might have several decent used parts I can let go pretty cheap including 6-spline pinion(s), seal housing(s). I'd be slow to ship & from Canada.
It's all doable my friend, but ya need patience & $. Keep looking for a manual.
I'm going to try and get some pictures uploaded. I'm not sure my machine is that similar to yours. Like you said a picture is worth a thousand words sometimes.(quoted from post at 08:46:38 03/19/23) My pleasure! Any questions at all, ask away. If I can't help you, others will.
