I'm only guessing it's 1965 by pictures on the web but I have no idea what model it is.
Trying to give my new (to me) forklift a tuneup. I put new plugs in it but I don't know what cap and rotor it needs. I am assuming it's a continental engine 4 cylinder flat head. I'm trying to figure out the right firing order. It originally was set up as 1243 which did run but wouldn't get full RPMs and was running pretty rough. On the top of the head it has a firing order of 1342 but was way worse that way. The engine code has 5967 but each digit was crossed out and another number stamped next to it, 0368. The cap has a big crack in it which probably doesn't help and the plug wires are junk. But each cylinder is firing and noticeable when you ground out each plug.
It has the forward and reverse and fork controls on the steering column, if that helps any.
Does anyone know what engine this is?
I will also need to find out what fluids it needs.
For sure old school antifreeze.
Has ATF but not sure what type.
ISO 46 or 32 hydraulic fluid ?
And so on.
Thanks, any help will be greatly appreciated !
Blue
And so on.
Blue
