Hi all,
Still working through issues on this machine and have run into another one. I've changed the transmission filter and fluid and when attempting to use 2nd gear, the machine engages and will move forward but barely. It's as if a clutch would be slipping. First works without any issue. Third and fourth seem to work fine but I need to get the machine to smooth area of our property to really test them. Is there anything I can test/check to see if I can get 2nd gear working properly? Will running the machine in the other gears be a problem meaning will I damage anything else? I'm assuming it wouldn't if it's like a manual transmission. I can stay out of the gear and it should be fine. Any help is appreciated.
