1941 R2 Cat fuel pump
Forum,
I have a '41 R2 Caterpillar that has developed a leaky fuel pump. Not too knowledgeable about vintage fuel pumps but believe it involves a diaphragm. Does anyone have any hints of finding such a fuel pump. If I can not find a pump I may move to gravity feed. It looks possible if I have no air bound possibilities. Last question is why did they use fuel pumps and not gravity feed? Any and all thoughts are welcome.
Thanks
Try this guy. He rebuilt a pump for an R4
that I had.
Believe it or not a lot of parts were available from my local Caterpillar dealer. The following web site will help you find those NLA parts :
https://www.acmoc.org/about/machines/r2
(quoted from post at 14:15:38 07/20/23) Try this guy. He rebuilt a pump for an R4
that I had.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto159101.jpg>
Thanks for the replies! Will contact tomorrow.
I would assume the charge pump is there mostly because its
there on a d2 to feed the injection pump. Ill look tonight
through the microfiche at the farm. So you want a part number
for pump and gasket behind it? Anything else?
It needs a fuel pump because of the extreme angle crawlers are expected to operate at... the fuel flow to the carburetor could cease at a great enough angle ... same reason most dozers have two oil pumps.
I had a 1939 R2 that the diaphragm leaked--couldn't find a replacement so found a diaphragm the same size and replaced it--can't remember what car it was from
