john deere 2040 clutch
showell69
New User
I have a John Deere 2040 that needs a clutch kit. JD parts call for an 11 inch clutch but when I measure the actual clutch it is only 10 inch. My splines match the ones on an 11 inch clutch but not what is on a 10 inch clutch. Does anyone have experience with how to measure my clutch disk or with replacing the clutch in a jd 2040? My tractor is one that was manufactured in Germany and is a low serial number <350,000.
Measure the bolt circle of the pressure plate. Looking at the online parts catalog and some cross checking using the A&amp;I numbers it looks like JD # AL120022 pressure plate is called 11''. RE29882 traction clutch disc used with it shows up as 10''.
If you are looking at buying a kit and want to be sure, call/contact the vendor and get verification that the kit matches the components from your tractor.
This post was edited by Jim.ME on 07/26/2023 at 04:29 pm.
