steve n carol
early 70's Crawler loader / backhoe 450, SN#3064032
While scarfing w/the teeth on the bucket and pushing some small trees & roots, the engine sputtered, lugged down and died. My first thought was that it was fuel related.
Checked the settlement bowl for water and made sure that the petcock was on. All good there. checked for fuel flow / water at the filter drain. all good there. tried to re-start. Motor, (saw the fan), turned over sluggishly maybe 4 revolutions and would stop turning. I did this 4-6 times.
I thought the battery was dying, it's 8 yrs old. So I let it sit for an hour. Tried again, same results.
I jump started it. It started sluggishly, sputtering, but i held the starter button in. Assisting w/the starter. I saw the hyd lines 'shake' and the engine started.
Loader was not in the 'float' position, the backhoe was not on, (been off for a year).
Went through both hyd screens and new tech hyd fluid (OEM) 70 hrs ago.
Crawler ran fine the rest of the day.
I did read in another post where this happened. It was found out that a relief valve had some foreign material in it and was blocking the flow.
Any ideas?
sl
Any ideas?
sl
