Cracked head.... water jacket and of course, the bolster for the radiator mount. I can get this cub for a song, but maybe it's too much problem. I intend to use it lightly around the property. It runs, just cracked.
The head can be replaced easily enough. I know JB weld will work for a while.
This Cub is a 1960. what later years are compatible? I see a 1977 head available...will that work?
What about welding the front bolster...very thin horizontal crack.
I have welded cast sections before..welded a B275 tranny that broke in half.
If I choose to weld the bolster, what rod and technique is best? Do I use pure nickel or alloy? Small sections? Peening? Pre-post heat?
