Happy Dave
Hi, first time posting, thanking you in advance for advice.
I have a 1948 Farmall Cub that has been sitting under an open shed for 10 years. When we tried to start it found the clutch was stuck, and using the hand crank, we turned the engine to see if engine was stuck.
It turned freely for about 6 time then can to a hard stop. Removed the starter and reversed the engine rotation using the flywheel teeth one full turn and it came to a hard stop again. Tried the a couple more times to turn with crank then it felt real tight at the stop point but kept turning. After 3 revolutions it turn completely free. Replaced points and condenser, cleaned carburetor and it started up and would run for 15 to 30 seconds and stop. After a few times doing this, it suddenly hit a hard stop again.
What is causing this hard stop? Could it be something to do with the stuck clutch? i am not a mechanic and my Brother who works on his own cars but is helping me is not familiar with this type of tractor.
