Happy Dave
HI, am not a mechanic and need advice, thank you in advance for your advice.
I have a 1950 Farmall Cub that does not have electric to spark plugs. It has a generator with a voltage regulator attached and is a 6 volt system.
I wanted to use a generator (not alternator) from a totally dissembled 1953 cub to test if it was the problem. Not sure if the '53 cub is a 6 volt system vs a 12 volt system. If it looked the same I would simple remove and replace with like kind item, but it doesn't .
Items that are different.
1. voltage regulator of 53 is detached from generator and has two sets of point in it, where the 50 only has 1 set of points and is attached to the generator.
2. the center wire of the distributor cap goes what looks like a coil verses the magneto, which I thought only occurred with 12 volt systems.
They are so old there is no writing of any kind on the generator or voltage regulator. as the 53 is totally dissembled I do know what wires connected where.
I would post pictures but have not figured out how to do it yet
