crsutton81
The original post is getting buried so I started a new one. This is how mine is setup. The gentleman that originally had this unit made this flip over block to fall into the crack between the pedal and the floorboard. It hinges on the 1/4 inch floorboard belly pan bolt by the clutch pedal. Hold the clutch with your left foot, and use your right toe to lock / unlock it. Works pretty well. The block portion is 1/2 incch thick.As to the belt, it should be 60 inches long X 5/8 wide....if there is a waterpump on your Super A, these measurements will work. I would try a notched belt if possible. I have not tried one yet,but I believe it would work better.
