Looking for Super C Weights
I already posted on the classifieds, but I'm not able to post a photo. I'm looking for a set of wheel and side weights for a Super C. We'll be traveling through AZ, NM, OK, KS, and CO this May. Would really be convenient if anyone had them in those states versus shipping cost. Thanks!
C , H , and M front weights are all the same. Should be easy to find where you live. I actually brought a set home to Ontario from Oregon , just because I came across them and decided to bring them home in the van. I later found two pairs close to home
I'm thinking Michael is right about the front wheel weights being the same as H and M. Only, I'm thinking the rear weights are also.
Those side mounted frame (I guess you'd call it) weights, I don't think I have ever seen those before. Those might be harder to find. Especially if they only fit a C.
yeah the rear weight are readily available,in most areas, well they are here anyway, they are the same from a C to a 1456, maybe the 66 series too, and they later made half weight's. But the front you might have to look for them, or else you might have to create some out of flat metal, i had place make me some smaller suitcase weights back in 2002, but steel was a lot cheaper then!!
Try J. P . Tractor salvage in Fredricktown MO he probably has some or has some coming in on one. It is a salvage yard as the name implies. He also sells whole used tractors too. Look up their website for used tractors or parts. Not sure what it is. they were good to deal with when I dealt with them the time I did.
Frame weights fit C, SC, 200. Not sure about 230?
If you can find a pair look up current price of gold then figure 1.5X for the frame weights.
Over here there are like four of five sets of ft. wheel weights on Face book market place at this time . Rear weights all over the place as they fit EVERYTHING from a C on up into the 88 Series an not sure after that as NOBODY around here has anything newer. As for the nose weights don't see them vary often . BUT like everything else the prices are way over priced .
