Mounting a Spool Valve on a H
Triker
04-10-2007 08:37:35
Guys, Just bought a 2 handle spool valve and don"t know where to mount it. I am guessing it is too heavy to hang on the light bar so most likely I would have to have something fabricated to hold it. Does anyone have pictures or idea on how to mount this thing? If anyone would like to make one for me and I will gladly pay for your services, within reason. I am not too good with that sort of thing and don"t have anyway to make one. I would like to get this thing going so I can hook up the loader and 3pt on the old 39 H. Any suggestions is very much appreciated. Ed
SDE
04-10-2007 13:54:53
 Re: Mounting a Spool Valve on a H in reply to Triker, 04-10-2007 08:37:35
Someone mounted a piece of pipe on the fender of my C. I think he may have either used it for holding an umbrella or for some type of hand tool. When I needed to mount a spool valve on the C, I added another pipe over the top of that pipe, and the valve mounts to a bracket welded to that pipe.
Wardner
04-10-2007 11:22:30
The valve can be put anywhere if you are willing to consider a remote connection. On the tractor below, I used a snowplow "joy-stick" and cables to run a two spool valve. Most valves have provisions for mounting solinoids. That gives you another option. Hoses can be expensive so you might consider selecting a location that reduces hose length.
third party image
third party image
Steven@AZ
04-10-2007 11:34:05
 Re: Mounting a Spool Valve on a H in reply to Wardner, 04-10-2007 11:22:30
MORE PICTURES!! What tractor is that? Where did you get the gearbox, etc? Front mount snowblower?
Thanks!
Wardner
04-10-2007 11:40:57
 Re: Mounting a Spool Valve on a H in reply to Steven@AZ, 04-10-2007 11:34:05
That is an Elwood FWA gearbox. I have a few more pictures but it will take awaile to upload to Photobucket.
Wardner
04-10-2007 12:10:44
 Re: Mounting a Spool Valve on a H in reply to Wardner, 04-10-2007 11:40:57
Here ya go. The tractor is a 660D built near the end of its production run.
Looks like, between you and I, we will be heating up Photobucket's servers this afternoon.
third party image
third party image
Steven@AZ
04-10-2007 10:15:30
I made a stand for mine that bolts into the threaded holes on the axle housing made for bolting on the fenders.
third party image
third party image
RustyFarmall
04-10-2007 11:56:53
 Re: Mounting a Spool Valve on a H in reply to Steven@AZ, 04-10-2007 10:15:30
Steven, that is very similar to what I did on a super M about 20 years ago. Wish I still had that tractor.
unioncreek
04-10-2007 11:17:26
Steven,
What kind of pump is that you have mounted.
Bobg
Wardner
04-10-2007 11:37:15
 Re: Mounting a Spool Valve on a H in reply to unioncreek, 04-10-2007 11:17:26
I don't know what Steven is using but here is something easy and simple to setup. It is a Fisher Snowplow pump/reservoir in one unit. Not alot of volume or capacity. I think performance would be similar to a power steering pump.
third party image
Steven@AZ
04-10-2007 11:31:58
Cross brand with max rpm of 3600, but I only run it 2000rpm for around 15 GPM.
wh
04-10-2007 08:59:13
i have a "live" pump on mine. did have a single spool on the belly pump before. simply run the pressure line to one side (in) on your valve and the return line to the fill port on the belly pump. engage pump and it will work. link shows how i run an external tank now with the live pump and 1 set of remotes plus the 3pt. on a twin valve. scroll to see additional pics.
