Tea20 no spark
todduter
New User
Has been converted to 12 volt, 1 wire alternator
Key switch with push button
How do I bypass the key switch, it seems to have no power to coil, I also replaced the coil
Thanks
This based on your tractor being negative ground. A jumper wire from the positive battery post to the + terminal of the coil will bypass the switch for a test. The - terminal of the coil should have the wire going to the distributor connected to it.
With 3 positions on the switch, one terminal is for battery, one for ignition, one for lights. Connect battery to ignition and you have bypassed the switch. If the lights come on, you have the battery connected to the wrong terminal.
These are my go to Manuals..
Tractor has been on my property since new.....
Bob..
as..
