Richard JH.
Good morning all,
Am working on an old TEA 20 that has sat for dacades.
Got engine freed up with mostly patience, plus ATF and acetone sprayed in through the plug holes. Rocker cover off and cleaned up of rust, no valves sticking but cam followers did for a while!
oil changed and water drained. a little oil on top of the water ...but hoping!
It turns over nice now, using a hind wheel.
I drained the gearbox and final drive, as the oil had the usual water in it, then figured maybe I should change the PTO shaft to 1 3/8", from the old 1 1/8".
Its a gamble, because I don't know if it will run yet!...but as all three rear end plugs are out, it seems as good a time as any, and it needs a PTO seal anyway.
So Gents, My question is, I see these replacement PTO shafts complete with bearing and such on Ebay, but they just say for a TE -20 & TO 20.
Is this the right shaft for a TEA -20? I believe so but wanted to check here.
I see this site has parts as well, but wonder what the exchange rate would be and shipping to Canada?
BTW, this little tractor looks to at one time had a paint job done to match the Fergy 35, silver and red.
All the best,
Richard.
All the best,
Richard.
