2000 for 3cy wheel weights.
kenbob
Is new holland part C5NN1A002M the same as 960e-1076...or more simply will both of these numbers work on a ford 2000 3cyl 28 wheels.
Thanks all.
30 & 40 REAR WHEEL WEIGHTS FOR POWER ADJUSTABLE WHEELS - 4100, 5000, 7000 (NHNA) from the parts book, so unless you have power adjust rims.. I'm guessing they will NOT fit. I would get the dimensions of the external and mounting holes.
You seem to be knowledgeable of Ford parts. I found other weights, that somewhere on this site said they would fit the 2000 3cyl. They are part nos 960E-1076 and 1075. The guy measured the hole spread and he says it is only 13 inches.....would this be for spin out rims as well, or was I misinformed.
Thanks again.
(quoted from post at 11:01:53 12/04/22) You seem to be knowledgeable of Ford parts. I found other weights, that somewhere on this site said they would fit the 2000 3cyl. They are part nos 960E-1076 and 1075. The guy measured the hole spread and he says it is only 13 inches.....would this be for spin out rims as well, or was I misinformed.
Thanks again.
The 960E-107x weights are for the standard wheels on the 2000 and 3000, which are 28" manual adjust wheels. The C5NN1A002M, which looks to have been superseded over time by C7NN1A002B, are for the power adjust wheels on the 4000, 5000 and 7000. I think that the Original Post was assuming that we knew that the 960E-107x weights are for the 2000/3000 manual adjust and was asking if the C5NN1A002M weights were the same.
The weights are in 2 different locations. The guy that has the ones with the 107x part numbers says he measured the holes at on 13. Since
there are 2 sets of holes I wonder if he is measuring the right ones.
My problem is that a lot/some of 2000/3000s come in when a non factory rims... for what ever reason. Either earlier? or from a furguson?? or what ever. SO.. I would measure the 3 weight mounting holes on the rim. for size and diameter... and the biggest the weights can be and the smallest they can be. then at least you have a chance of getting what you need. After 5 posts, you can also post pictures and that might help us identify which rims you have. Sorry to be evasive.
