ford 3000 hydraulics
hoops
1967 ford 3000. hydraulic lever out of adjustment? when pulling up on lever hydraulics only work when lever is almost at top of quadrant. At that point lift arms are erratic as in jerks, as in sensitive to control operation. Guys hope this makes sense. Appreciate any advice.
Probably in draft control. Try the small lever on the right side below the seat. If it's pointing up push it down. Or if down pull it up and see
how it works.
If it made no difference whether in Draft or Position Control mode, it likely means that the cam follower pin is worn and no longer a round pin. That is probably not related to the jerkiness. That is likely a whole different cause.
