steveo3000
Hello! I have begun the journey to revive my inherited (Dad s) 1966 Ford 3000 gasser, and I m wondering where to go next to solve the backfiring problem I currently have. It has spent its life indoors, probably spent the better part of the last 10 yrs sitting.
I have both the service manual and operator manual to consult.
It ran good for the years prior to sitting.
What I ve done so far:
-Carb clean/rebuild
-Replace fuel tap on/off
-Replace spark plugs
-Replace fuel lift pump (was spitting gas from weep hole)
-Cleaned mouse nests as I found them
-Removed rotted muffler (straight pipe at the moment)
Point of interest:
-Wire from the distributor (power wire I believe?) is basically chewed thru, hanging on by a couple strands. It seems both ends have seen better days, would be best to replace this wire. Are the Pertronix igniter products that much better over the point condenser replacements?
-Vacuum line at the advance assembly came apart from the fitting. I cleaned off the fitting, inserted it back in, and just shoved the copper tube into the center. Probably should take it back out, flare the line and make it proper.
-Backfire is from the exhaust and also back thru the bottom of the carb. Gas leaks out the horn/plate on the bottom.
Next step:
-Inspect distributor cap closer, and confirm rotor rotation to also verify correct plug wire attachment. Long story short, I did not label them before removing, and need to confirm I have it correct moving forward.
-Consult like minded individuals on this forum to gain knowledge on this machine. More interested in testing/repairing it myself versus calling the mechanic.
This post was edited by steveo3000 on 03/13/2023 at 08:29 am.
-Carb clean/rebuild
Point of interest:
Next step:
