Noel Putman
Ok, the saga with this auction ford 2000 3cy diesel tractor continues. I guess this is half of the fun of working on old tractors; the surprises that come up.
I changed out the injection pump, albeit with an aftermarket one. I still have the original pump, but threw this one on there kind of to diagnose the hard starting condition. Would not recommend this route as the first pump leaked and a lot of time was wasted re-removing and waiting for a replacement.
Anyway, issue is that both the replacement pumps had clearance issues with the starter. The bearing cap of the starter hit the inlet end of the injection pump. The original Lucas CAV DPA fit fine. In fruswisdom, I filed a bit of material off of each to make them fit. Now I am concerned that if the starter goes bad in the future, I am going to be left with removing the IP to replace the starter.
Is anyone aware of a long and short version of starters on Ford 2000 3cyl diesel tractors? Anyone run into this using an aftermarket IP?
Thank you.
Thank you.
