So I'm somewhat at wits end right now with this 2000 that I picked up a month ago. I had the holly carb and wasn't getting fuel, so I cleaned everything and installed a new fuel pump. Then couldn't keep the fuel out. Every post I saw said to buy a zenith, so I bit the bullet, ordered a 13913b, and that came in.
Installed it last night, Opened the fuel valve, and she cracked right open until 10 seconds later, it bogged down and died, pouring fuel out of the carb air intake. I went in and bent the float down a little bit, and I had the same problem. Runs for 10 seconds and then pukes fuel out. Passes the "blowing on the fuel input" test for stopping fuel flow into the bowl, but as soon as I put it on the tractor, it runs for a bit and spits out fuel. I resorted to trying to crack the fuel valve only a bit and metering that way, which sort of works but seems like a dumb way to do that.
What am I missing?
I think the only reason the carb should be pouring fuel out would be a flooded bowl, correct? The only other thought is that that zenith is not supposed to be fed by a pump and should be gravity fed, but that doesn't make much sense as everything I have read says the zenith is plug-and-play.
>Edit for wording and Clarification
This post was edited by PWaubs on 03/28/2023 at 03:15 pm.
What am I missing?
