At long last I lucked out locating a pair of correct front wheel weights for my Fordson Major . Best part was they were only 60 miles away. The owner found them under hay and chaf in his old barn & advertised them on Marketplace in Facebook. They have the En Fo stamp on the inside face. I had to make up the 8 mount bolts using heavy flat washers welded to the underside of the bolt head then pattern the flat washers to fit the slotted holes where the bolt heads reside in the weights .. I,ll post a picture.
This post was edited by MarB on 07/06/2021 at 04:55 pm.
