Hi, I was given some great advice on here regarding my frozen fordson engine and today got round to removing the injectors and adding a little atf fluid to each cylinder before putting everything back together again . I was going to leave at least a week and before trying to do anything take out the injectors to reduce compression and have a go at turning the engine. My question st this point is whats best point to try, crank pulley or starter ring gear with a long crow bar? The crank pulley is a very slim bolt with no starter dog attached so ring gear would be good but I don't want to break anything.
If this doesn't work next plan is to remove the head and start tapping the piston s to see what's stuck. This is definitely the last time I leave a tractor outside again tho. Thanks in advance
