Double groove pulley for Fordson Super Major
Bluemthorse
New User
Looking to install a power steering assist on my Super Major. Looking for a double groove pulley to run the hydraulic pump for it, but one isn t shown in the parts lists Any advice on one that will work??? It is an Agriline power steering assist. With the mounting of the pump just below the generator, 1 pulley doesn t look like it will work
Bluemthorse
This post was edited by Bluemthorse on 08/01/2023 at 05:31 pm.
The drive for the power steering pump was taken from the water pump. There was a special
extended shaft, hub and pulley. I believe most Major and Super Major tractors over there were
fitted with power assisted steering so you might be lucky picking one up second hand from a
breakers.
Thanks for the info Majorman!!! Will look for that type of drive instead.
(quoted from post at 04:12:36 08/02/23) The drive for the power steering pump was taken from the water pump. There was a special
breakers.
