caterpillar guy
Dad is looking for the clutch disc that goes into his Gravely mower. It makes the drive connection for forward and maybe reverse. I didn't get to look at it very much and he says the clutch disc is maybe bonded to one of the metal castings the squeeze it tight to move. I realize this is probably looking for a needle in a hay stack type of thing. Or where in the Mid MI area is there a place I could take it and they could put a new lining on the casting for it. It goes down inside the right wheel and is about 5-6 inches in diameter I would guess with out measuring. It is one of the original zero turns I would guess with the steering wheels behind it and drive with a roller chain from in front of you connected to the steering shaft mower deck is out in front of you. I don't know the model nor have pictures. Though I might be able to get some later.
