Kohler Magnum knock
circus
Blowing snow with a Ariens GT18. Everything's fine til I idled it down and the engine started knocking. Still blows snow at full speed no knock. Before I total it, is there something other than a rod that could cause a knock at idle?
photo similar to my engine.
[/img:616e9bb798]
A loose flywheel or drive pulley could knock.
Carbon between the head and piston can cause a knock, as well.
A couple of years ago I had a knocking (probably worse at idle, too) Onan in a Deere 318 and that's what it was.
That Onan and your Kohler are very similar in size and design.
Surprisingly, the official service manual doesn't list carbon as a source of knocking. You can check it out/download it at the link below and check out the troubleshooting section.
https://resources.kohler.com/power/kohler/enginesUS/pdf/tp_2204_b.pdf
I had the vertical shaft version of that motor in an Ariens tractor. Ran great! Never any issues with it. Idling it sounded like a Harley Davidson. Great that you found
the issue, easy low cost fix too.
(quoted from post at 09:17:48 02/25/23) I had the vertical shaft version of that motor.... Idling it sounded like a Harley Davidson.
Harley?? Something wrong with it??
Thanks, occasionally one catches a break. Phew..
