Morning: I have this tractor brought in for get it going like it was before it was
worked..so I have been looking for a PDF file or any diagram for the linkage
connections/assembly for the Case 444 belly mower and tiller attachments, also can both be
attached the same time but used separately ?
The tiller mount is the square tube system with a linkage to the multi hole plate under the
right foot pedal, at present there is only an inch+ of hyd cylinder movement before things bind
up, neither attachment is usable due to lack of movement.
tks
tks
