1946 BN IHC
We have a case 224 Ingersoll Rand. Have noticed that the main driven pully on the deck is on downward angle [not level to the ground] this is causing the belt coming off the angle drive pullies at an angle of approximately 20 degs., downward at the front of the driven pully.
>>> to my thoughts it should be level to the ground so the belt comes off the angle drive pullies flat when the deck is down at cutting height [middle hole on quadrant]
What do I do to correct the driven pully angle and deck angle. There must be something that I am not seeing correctly, that is either warn or bent allowing the front of the deck to be lower than the back causing the pully mis alignment.
Wm.
Wm.
