Allis Chalmers Plow Question
C.Amick
I have a single bottom mounted AC plow that I need to sell. Did the B Series or C Series tractors use the same plow?
Maybe some parts, but not the same mounting system as the WD etc. I've never seen a single bottom for the larger tractors.
AaronSEIA
I believe the plow and the mounting rods and braces that are attached to the plow are the same. There are different configurations of rock shafts (hydraulic lift single or dual, and hand lift) and I think those parts will all work to lift the same plow but each of those set ups needs to be complete to work. Have bought a couple of those plows for tractors over the years and the mounting parts are harder to find than the plows. Good luck, Mike
I have never been around the plows but one look at the tractors should say NO. The B is a single row cultivating tractor while the C is a 2 row cultivating tractor. So that means the wheel tread is quit a bit wider on the C so there would have to be different mounting parts to allow for the wider wheel trad spacing. Unless parts are made as adjustable to allow for the wider wheel track.
