SoCalFarmin
i have a early 60s MF 65 Perkins diesel 4 cylinder. when I got it about a year go, the previous owner had just had the FIP rebuilt. The tractor ran fine for the first few times I used it, then starting "hunting" I also noticed that it would run for half an hour then die and would not restart until several hours had passed, usually the next day. Over time the operating time got shorter and shorter and the "hunting" got more and more pronounced. One day after several attempts of starting and running for 30 seconds and then dying, it would not start at all.
i took the FIP to be serviced. i got it reinstalled and the tractor ran beautifully, the hunting and high idle was fixed. On the 3rd time I used it, it died after a half hour of running. the next day it ran for 15 minutes. Then only 30 seconds, then it wouldnt start at all.
I checked the fuel filter, cleaned out the fuel lines from the filter to the FIP and bled the lines to the injectors. I got it to run again for 30 seconds, then it died. WHen it dies it always winds down the same way as when you push the fuel shut off valve.
Whats the next thing I should do?
