Cariboo4x4
My friend Rod has a gas z134 continental 4 cylinder in his MF35 tractor. It has an engine needing a rebuild particularly a better crank and couple connecting rods. It has a hydraulic loader setup that gets its hydraulic oil from a block on cover under front of seat. We put a new hydraulic pump in it and then shortly after that a connecting rod big end started knocking. He located a 1956 MF 35 and I wonder how much of the 1960 parts such as the loader set up, hydraulic pump, hydraulic block under front of seat would work on\in the 1956 MF 35. The 1956 has a Z134 continental 4 cylinder in good condition. Basically the 1956 is ready to go yet wondering if loader set up from the 1960 will bolt right on. We plan on going to look at the 1956 next week.
