Hello again.
I got a look at the KTA today and here's what I found.
Radiator was dry and crusty inside. I'm guessing it will need a new core. Replaceable I'm assuming.
Valves were free for 6. 2 were a little sticky. No biggie.
Brakes, shift lever, gas tank, looked / worked good.
Removed engine side plates and what I could see looked good.
Not sure about clutch. The lever moved but not real far.
Oil in pan was quite thick on stick. But when I removed pan plug I got water and antifreeze.
Couldn't crank it.
23 degrees in the shed.
Are head gaskets available?
Couldn't crank it.
