TCPDRETIRED218
O K here is the deal the engine, is still frozen SOLID ( SEE PREVIOUS POST } I'm going to split the case tomorrow just to make sure its the engine.I managed to remove the end caps from two of the pistons. the other two pistons are stuck at a point where I can remove one of the end cap bolts on each cylinder, but the second bolt wont come out as it hits the block stopping me from removing the bolt. Cant drive the pistons down as the rod hit the crank.
is it possiable the crank is frozen as opposed to a piston or two being seized up?
Do I really have to remove the cam to remove cylinder block, and how should I go about looseing them from the engine block they sit on.I was thinking if I could pull the block up and get the last end cap bolts removed then take block with pistons en cased to the machine shop and let them have at it
looking for some words of wisdom here. as you can see I,m about of ideas
