TCPDRETIRED218
I have one more leak to fix and the Jet Star should be all ready to go.
my question/problem is this.
the power steering pump/valve body (?) which has 4 hyd lines leading in and out of it is leaking. This leak is coming from a small hole in the rear center of the pump/ valve unit this hole has a small L shaped wire protruding from it.
the leak weeps out of this hole very little while the tractor is sitting and considerably more while the engine is running but not a lot.
I cant seem to find anything out about this hole and wire in any of the manuals, shop, parts, owners.
Wonder if any one can shed a little light on this for me and how I might fix this the leak?
Thanking you an advance!
