I've never seen a Bulb new without the internal screen attached but then I buy from only 2 or 3 quality suppliers -see LINK below. The screen is soldered on, original
anyway, so no, not reaaly worth it to try. Is the gasket cork or rubber? Should be a 2 cork gasket. Again, it matters where you buy from. Cheapo Asian made stuff
today is usually junk. Was there a problem with the old Sediment Bulb? Leaking issue? If that was the case, there are two usual culprits. The first is the Valve Stem,
p/n APN-9194, a $6-7 item. It is the only part on the Bulb that wears. There is a rubber 'seal' that eventually gets chewed up and thus will leak. The 2nd is if the
threads on the bulb got boogered up and cross threaded. Fueal and Barke liens use special therad size, 7/16-24 UNS. The Bulb Assembly is made of aluminum, and can get
cross threaded if not correctly fastened. Always start these fuel fittings by hand first so you get the 'feel'. With a new Stem you get the knurled knob with the 8-32
screw an star washer. I highly advise you aply a dab of ThreadLocking Sealant when you assemble it. The knob screw is prone to failure as it may loosen up and thus the
knob falls off, and it's always in the field when you don't notice it, only realizing when you go to shut down the tractor. Be sure to get the filter that is soldered
onto the brass fuel elbow at the carb. The elbow has to have the fuel line removed first and it uses a 1/8-NPT thread to carb.
SEDIMENT BULB VALVE STEM, p/n APN-9194:
NOTE: WORN SEALS
Tim Daley(MI)
SEDIMENT BULB ASSEMBLY
