(quoted from post at 05:59:07 03/26/23)
(quoted from post at 10:42:14 03/25/23) The casting and radius arms are off the tractor and on the bench
As you've probably discovered, may have been easier with the axle still on the tractor. Gives for more holding everything solid better. Maybe not a lot easier, but a little
I have an oxy acetylene kit from my A/C days, but have no idea of how to use it to free the pin. Do I heat the pin, or the casting and how hot?
In general, you heat the part that is holding the other part, as heat expands. You don't want to expand the pin. You would get it good and hot, probably almost red.
The challenge comes when the part holding is a heavy piece, and the part that is held is lighter. By the time you get the outer part hot enough, the heat has transferred to the lighter part, expanding all.
I have used my torch more times than i could possibly count to loosen up stuff. But using a torch, and not getting the part loose, then cooling, can sometimes make it even harder to separate. Sometimes, drilling, dissecting, etc is the only way.
Since your axle is off the tractor, the axle is heavy enough that a strong shop press would probably do it. If you do get to a press, Be Careful!
