Hi:
Tractor running hot. I checked water level and found oil in radiator. Traced problem to transmission. I believe problem to be heat exchanger on top of the transmission.
Is the heat exchanger repairable?
Is that the only place where coolant and transmission fluid can mix?
Any recommendation for cleaning out the radiator and block to flush out the transmission oil?
Same question for cleaning out the transmission but to remove the water?
The Agco books imply a change at Serial number 196 205 and my Serial number is 198 209 but I cannot see any difference. Should there be?
Thanks
Thanks
