theking5983
I cannot find a hydraulic pump for my Oliver 1550 the pump is a Cessna B24318 0AAA with the 9 spline shaft I cannot find a new pump or a rebuild kit or a pinion gear 155741A from a 1650-1655 to convert the tractor over to run a 1650-1850 hydraulic of which I told is the way to go because the pump have a higher GPM flow which if someone let me know if that is true would help out as well, I did find the gear to convert over to the 1650 pump just ordered the pump should be back in the field this week thanks everyone
This post was edited by theking5983 on 06/13/2023 at 09:11 am.
