Super 55 Brakes Grab
Ohiohills
Has anyone experienced a problem with the brakes grabbing on a Super 55 (s/n 23 490-518)? I want to have a tractor with effective brakes, but the brakes on this 55 are very touchy ... any more that a very light application of the pedals causes the brakes to grab. Sometimes, even if the brake pedals bounce excessively when going over rough ground the pedals will bounce enough to cause the brakes to grab. Any suggestions?
Also, I found that if I torqued the bolts to spec, it is too tight. Try loosing off the bolts, but all means remove the cover and inspect the brakes, they are simple to work on.
