main pto shaft oliver 550
biged706
New User
Can not get pto shaft back in the last 8 inches or so. Seems like something happened to needle bearing in gear. Can not see in that far. Any ideas?
If the tractor is split you can slide a
pipe in from the front. Use that to guide
the driveshaft through the bearings.
(quoted from post at 17:27:21 10/19/23) If the tractor is split you can slide a
Thank you that will help.
