Is this a Cockshutt 550 - as in the old, true Cockshutt? Or is it an Oliver 550 (which were confusingly also rebadged as Cockshutt 550's here in Canada) ?
There's a cover underneath that you take off to access the clutch. Sounds like it needs to be adjusted. It's possible that it's loose, but too, that it's too tight and not going over center. You'll have to have somebody move the lever while you lay underneath and see what's going on. To adjust it, there's a spring loaded pin that you push in while you turn the collar. If you search You Tube you can probably find a video that shows you the process.
DanielW,
EXCELLENT QUESTION. I wonder too???
BRANTFORD, ON CANADA ON BUILT REAL REAL 550 has 38 inch rear tires.
USA built OLIVER/COCKSHUTT 550 has 26 inch rear tires
Phil Heisey
215-256-8651
(quoted from post at 05:22:48 10/23/23) thank you I will check that out today.
I had the same problem with mine. Just needed an adjustment.
Would of been easier with 2 people though.
https://forums.yesterdaystractors.com/viewtopic.php?p=11054197&highlight=550+pto#11054197
