(quoted from post at 19:46:11 03/11/23) What is the strongest clutch for a 460 making to much power for the old one
You may need to go to a multi disk setup. What engine are you using and what kind of power are you making?
If you are still using the stock setup, you can put a slightly larger flywheel in there from a 656. If you do have thoughts of doing more in the future, I d go ahead with a twin disk now. All of that said, I have a 560 with a similar engine setup that we pull up to 10,000 pounds and a six pad single disk holds fine for us.
Im running a new button clutch disc with a 60 year old pressure plate and havent had any problems at all. 560 at 105 hp 7000 lbs. May I ask what all was done for you to get 125 hp? Lee
Sorry for being nosy. I had pictured in my head you where running a stock 301 on 15.5 tires and 87 octane gas. (lol) Lee
