Oliver super 77
The frame is heavier, axles and bull gears are a little bigger and brakes would be heavier. Probably around 2-300 lbs. Our rowcrop 77 makes 3500 lbs with nothing special done to lighten it up.
Thank you. I have seen many 77s in 3500.
I have a super and was wondering if it
Would easy. Sounds like no , thanks for the info
The tub is most of it. And you can buy one made out of tubing and sheet metal. Have a buddy with one. On a 770. He is big and with 18.4's and a 320 block just weights 3700.
(quoted from post at 05:51:53 04/29/23) Thank you. I have seen many 77s in 3500.
It apparently depends on your definition of easy.
It is easy to put pressed steel wheels on
A regular 77 and make 35. Just wondering
What all id have to do to get a super that
Light
